方案下载应用领域 | 制药/生物制药 |
检测样本 | 化药制剂 |
检测项目 | 含量测定 |
参考标准 | 暂无 |
In analytical HPLC good resolution is required over the entire gradient; in preparative HPLC it is only important to achieve good resolution around the target compound, which should be collected in highest purity. With a small set of optimized gradient methods a much better resolution can be achieved than with a single generic method. The generation of a small method set based on retention time windows in the pre-preparative analytical run is described in this Application Note. Using Agilent standards with known elution properties makes this an easy four-step process, which can be accomplished in less than one hour. An application example demonstrating how the resolution of the target compound can be improved is also shown.
Abstract
Introduction
Baseline separation of peaks is required for accurate quantification of compounds in analytical HPLC. Therefore, a resolution of about 1.5 is needed if the peak areas are not too dissimilar. A good resolution is only required for the target compound in preparative HPLC1, and that compound is required with high purity. The separation of the remainder of compounds in the chromatogram is not of interest. Generic gradients of 5 – 95 % organic mobile phase are frequently used for purification runs, which do not always lead to sufficient resolution for the target compound. To increase the resolution an optimized method with a shallower gradient around the elution composition of the target compound could be used. Since the preparative method cannot be optimized for each compound this is achieved in practice by using a small set of methods. The preparative method is selected according to a retention time window, in which the compound elutes in the pre-preparative analytical run. The process of generating an optimized preparative method set for retention time windows in the prepreparative analytical run is described in an article by Blom et al. In this Application Note the process described in the article is simplified by using Agilent standards but it can also be performed with any other standard compounds.
Conclusion
In this Application Note the generation of a small set of optimized preparative methods based on retention time windows in the pre-preparative run was explained. By using the Isocratic Test Sample and the Electrospray LC Demo Sample the complete process was done in four easy steps taking less than one hour to accomplish. The improved resolution of or near the target compound using optimized gradients was presented in an application example.
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
