方案下载应用领域 | 制药 |
检测样本 | 生物药品药物研发 |
检测项目 | |
参考标准 | 暂无 |
This Application Note presents different online 2D-LC concepts for the high?resolution analysis of complex N-linked glycans in erythropoietin (EPO) using the Agilent 1290 Infinity 2D-LC Solution with fluorescence detection. EPO has a complex glycosylation pattern with differently branched and charged glycans. A combination of hydrophilic interaction chromatography (HILIC) with weak anion exchange chromatography (WAX) enables highly orthogonal separation. Comprehensive 2D-LC analysis with HILIC in the first and WAX in the second dimension facilitates high-resolution 2D chromatography together with simultaneous charge profiling. In addition, multiple heart-cutting 2D-LC analysis, combining WAX and HILIC separation, provides a flexible alternative whereby the user can select multiple peaks to be analyzed in the second dimension and, moreover, run longer gradients.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
