新型的LE 24/11 – 纳博热扩展了其成功的le经济型马弗炉系列
the new LE 24/11 - nabertherm expands its successful le economy muffle furnace series
我们很高兴的与您分享一些好消息!今天,我们自豪地向您介绍我们最畅销和成功的le经济马弗炉系列的扩展产品-新型的LE 24/11。该新进马弗炉可用于最高温度不超过1100°c的各种应用。像他的小兄弟一样,它是实验室中值得信赖的伙伴,并且具有很高的性价比。
we are pleased to share some good news with you! today we are proudly presenting the expansion of our best-selling and successful le economy muffle furnace series – the new LE 24/11. this entry line muffle furnace can be used for various applications up to tmax 1100°c. like his small brothers it is a reliable partner in the lab and characterized by a great price/performance ratio.
该炉仅配有外开式炉门,可在装卸料时用作工作平台。由于加热元件被包裹在石英玻璃管中并受其保护,因此加热时间短,可实现高效加热。双层外壳和优质隔热材料的结合可实现非常高效的功耗。
this furnace is only available with a flap door which can be used as work platform when loading or unloading. fast heating times due to heating elements encased and protected in quartz glass tubes provide efficient heating. the combination of dual shell housing and superior insulation materials results in a very efficient power consumption.
LE 24/11特别有趣,因为它是220-240v单相连接,而我们的L(T)24/11型仅适用于三相连接。此外,新型的LE 24/11--作为整个LE系列--在温度> 800°c、空炉、工作空间中具有+/- 5 k的出色的温度均匀性。
the LE 24/11 is especially interesting as it is connected to the 220-240 v single phase whereas our model L(T) 24/11 is only available with three phase connection. moreover, the new LE 24/11 – as the whole le series – has an excellent temperature uniformity of +/- 5 k in the empty workspace at temperatures > 800°c.
pid温度控制器专为简单操作而设计,它具有一个设定温度,该温度将一直保持到控制器关闭为止。
the pid-temperature controller is designed for a simple operation equipped with one set temperature, which is dwelled until the controller is switch off.
当然,此炉也可以配备我们的各种类型的烟囱。
of course, the furnace can also be equipped with our various types of chimneys.
您可以在下面找到le系列技术规格的详细参数:
below you will find a detailed overview of the technical specifications of our le-series:
灰化炉的装料架
charging shelve for ashing furnaces
除此之外,我们还为灰化炉LV 9/11和LV 15/11开发了一种全新的装料架,最高温度为800°c。
alongside this, we have developed a new charging shelve for our ashing furnaces LV 9/11 and LV 15/11 designed for tmax 800°c.
装料架上有两个封闭的和两个打孔的托盘,可将炉子分两层装载。交货中还包括一个便于搬运托盘的手柄。
the shelve comes with two closed and two perforated trays for loading the furnace in two levels. a handle for easy handling of the trays is also included in the delivery.
带有旋转系统和定制样品架的干燥箱
drying oven with rotation system and customized sample holder
纳博热也因其定制炉而闻名。我们拥有超过60名工程师,是工业炉行业中最大的研发部门之一。
nabertherm is also well-known for its customized furnaces. with over 60 engineers we have one of the biggest r&d departments in the furnace industry.
因此,我们很高兴为您介绍我们最受欢迎的定制解决方案之一-带旋转系统和定制样品架的干燥箱。我们看到越来越多的人咨询该系统。如本视频所示,它们通常与导管结合使用。
thus, we are pleased to present one of our popular customized solutions – the drying oven with rotation system and customized sample holder. we are seeing an increased number of inquiries for this system. they are often used in combination with vessels as shown in this video.
市场上几乎没有其他制造商能够以这种方式定制干燥炉。该视频将提供非常丰富的信息,有助于更好地了解旋转系统和定制的样品架。当然,样品架的设计可以根据客户的需求。
there are hardly any other manufacturers in the market who are capable of customizing drying ovens in such a way. this video will surely be very informative and helpful for a better understanding of the rotation system and the customized sample holder. of course, the design of the sample holder can
be adapted to customers’ requirements.
所有新产品已经包含在我们的价格表中,并且现在开始可用。 只有带有定制样品架的旋转系统需要单独报价。 与往常一样,所有产品均为“德国制造”。
all new products are already included in our price list and are available from now on. only the rotation system with customized sample holder would have to be calculated separately. as usual, all products are “made in germany”.
如果您需要这些产品的更多信息,例如报价、图片等,请随时与我们联系。
if you need further information for these products such as offers, pictures etc., please feel free to contact us.
我们期待您的回复。保持安全!
we look forward to hearing from you. stay safe!
防骗声明
纳博热(上海)工业炉有限公司即将参展5月31日-6月2日的中国国际粉末冶金展
Nabertherm GmbH即将参展(IDS)德国科隆牙科展览会
关于纳博热控制器升级的说明
Nabertherm 1400度马弗炉
Nabertherm带内置废气清洁装置的灰化炉
Nabertherm水平操作翻开式管式炉
实验室马弗炉Nabertherm-L 9/11
纳博热透明氧化锆烧结炉
高温真空炉/带石墨、钼或MoSi2加热元件的高温真空炉VHT
高温炉/带MoSi2加热元件的高温炉HT,作为立式炉
德国纳博热高温炉/带MoSi2加热元件的高温台式炉
德国高温干燥箱、空气循环炉,最高温度850 °C
德国纳博热箱式电炉/带砖(LH)或纤维保温结构(LF)的专业用箱式炉
管式炉/水平或垂直操作的翻开式管式炉RS
Nabertherm用于退火、淬火或钎焊的箱式炉
实验室灰化炉-Nabertherm-LV 9/11
实验室马弗炉-Nabertherm-LE 14/11/R7
Nabertherm干燥箱-TR 60
