Bruker Announces Innovative, High-Performance and Cost-Effective NMR Solutions for the Pharmaceutical Industry
Fragment-based Drug Discovery
Automated Small-molecule Structure Verification
On-the-fly Optimization of Chemical Processes
QC Raw Materials Screening, and
NMR Lab Connectivity
ASILOMAR, California – April 20, 2015 – At the 56th Experimental Nuclear Magnetic Resonance Conference (www.enc-conference.org), Bruker this week is show-casing several innovative drug discovery, drug development and process control solutions for small molecule NMR characterization in the pharmaceutical industry.
Fragment-based Drug Discovery (FBDD) Screening and Lead Optimization:
In recent years, FBDD has emerged as an alternative to traditional high throughput screening. The fragment libraries are characterized by the small size of the compounds and a smaller number of candidate molecules, aiming to identify those that may have initial weak-medium affinities for binding to the desired protein targets, and then optimizing these leads iteratively to obtain medium-strong binding affinities. At each stage, fragment-protein interactions are detected by highly sensitive NMR spectroscopy.
Bruker provides dedicated hard- and software for these FBDD applications: The SampleJet? high capacity sample changer with cooled sample storage keeps the delicate biomolecular samples from degrading, while at the same time providing maximum throughput. The specifically designed QCI-F CryoProbe? is a fully versatile, highest sensitivity triple resonance probe with additional fluorine capacity, enabling both, traditional proton- and novel 19F- detected FBDD capabilities. The CMC-q software ensures the integrity and correct concentrations of the fragment libraries. All these latest NMR tools together allow FBDD-by-NMR screens and lead optimization to be performed in a routine and partially automated manner.
Rapid, Automated Structure Verification Solution FUSION-SV?:
This new integrated solution for structure verification allows users to easily combine high-resolution accurate-mass (HRAM) mass spectrometry (MS), and complementary Nuclear Magnetic Resonance (NMR) data. FUSION-SV provides significantly increased specificity, robustness and throughput for rapid, automated small molecule structure verification. FUSION-SV is designed for the workflow of medicinal and synthetic chemists in pharma, chemical industry or in academia.
The proprietary algorithms which deliver this improved performance have been built into the FUSION-SV streamlined workflow and user-friendly interface. The medicinal chemist is guided straight to meaningful results with minimal interaction and without the requirement for expert knowledge of the underlying techniques. In addition to HRAM-MS and high-fidelity isotope ratio data analysis to determine an unambiguous molecular sum formula, using a Bruker Compact bench-top ESI-QTOF system, FUSION-SV 1.0 automatically analyzes 1D 1H and HSQC 400 MHz NMR data. The most advanced solution FUSION-SV 1.1 in addition requires a high-sensitivity CryoProbe? Prodigy at 400 MHz (or higher) to add the fast acquisition of HMBC and 13C NMR data to the automated structure verification analysis. The FUSION-SV database offers network access to the spectroscopic data, enabling collaborating scientists to share results and projects.
Process Optimization with InsightMR?:
This new solution for on-the-fly NMR analysis of chemical processes enables the adjustment of process parameters based on real-time data analysis. InsightMR? is built on Bruker’s NMR software TopSpin? for seamless integration with Bruker systems. InsightMR’s user friendly interface allows both expert and non-expert users to set up, monitor and adjust key parameters. As a result, it is an excellent solution for industrial and academic scientists studying and optimizing organic reactions. InsightMR has already proven successful with the first installation at Pfizer in Connecticut, USA, where it has been used to apply NMR to on-line reaction monitoring to solve real chemical questions within the drug development pipeline.
Pharma QC and Screening with AssureNMR?:
A customizable solution for evaluation of diverse materials using NMR. Built on the strengths of NMR for determining compound identity and quantification, and the highly reproducible nature of NMR, Assure-NMR? screens materials in full automation from acquisition to report. Integration with the spectrometer through system suitability verification and cross-checks before the sample leaves the acquisition queue assures that highest quality spectra are obtained before the data is analyzed and assists in making sure the SOPs are followed.
Whether the required analysis is for metabolomics, dietary supplements, reference standards, APIs, polymers, or raw materials, this customizable solution provides summaries of the sample composition and classification results in automation. Designed for compatibility with both research and GMP environments, AssureNMR provides rapid detailed sample analysis for research studies, product assessment and quality control.
LabToGo:
Access your data and view your spectrometer status anytime and anywhere with the new LabToGo app for the iPad. Powered by the ability of TopSpin? 3.5 to interface with cloud storage services of the user’s choice, uploaded data can be examined and visualized remotely. Additionally, the status of spectrometer automation jobs can be synced to the LabToGo app and automatic notifications can be sent for finished tasks.
“Bruker now offers a suite of innovative NMR pharma tools, designed for next-generation drug discovery approaches and more efficient lead optimization, for increased productivity and for higher quality,” commented Dr. Till Kuehn, Head of Pharma Applications Development for the Bruker BioSpin MRS division. “NMR is a robust, cost-effective, highly quantitative and information-rich analytical tool, and with these new solutions its utility for small molecule pharma applications has been greatly enhanced.”
About Bruker Corporation (NASDAQ: BRKR)
For over 50 years, Bruker has enabled scientists to make breakthrough discoveries and develop new applications that improve the quality of human life. Bruker’s high-performance scientific research instruments and high-value analytical solutions enable scientists to explore life and materials at molecular, cellular and microscopic levels.
In close cooperation with our customers, Bruker is enabling innovation, productivity and customer success in life science molecular research, in applied and pharma applications, in microscopy, nano-analysis and industrial applications, as well as in cell biology, preclinical imaging, clinical research, microbiology and molecular diagnostics.
【参会邀请】2024布鲁克核磁共振制药应用交流会:日程已更新!
布鲁克与国家蛋白质设施签订合作协议,共同推进高场核磁蛋白质研究
【新闻动态】布鲁克在韩国基础科学研究院(KBSI)成功安装1.2 GHz Avance核磁共振波谱仪
Andrew Webb和Bernhard Blümich教授荣获Richard R. Ernst大奖
布鲁克台式核磁共振波谱仪Fourier 80
布鲁克电子自旋共振波谱仪microESR
布鲁克600MHz核磁共振NMR波谱仪 AVANCE NEO 600M
布鲁克500MHz核磁共振波谱仪 AVANCE NEO 500M
布鲁克400MHz核磁共振NMR波谱仪 AVANCE NEO 400M
布鲁克台式电子顺磁波谱仪Magnettech ESR5000
布鲁克 LabScape Service & Lifecycle Su
布鲁克固体核磁探头续用 A2B 改装套件
布鲁克 AVANCE NEO 核磁共振 (NMR) 波谱仪
布鲁克SkyScan1276X射线显微断层成像
布鲁克 mq-ProFiler时域核磁共振分析仪
布鲁克minispec mq系列时域核磁共振分析仪
布鲁克时域核磁共振液滴粒径分析仪
布鲁克 minispec LF90II身体组分分析仪
布鲁克 minispec 碳氢化合物含氢量测定
