资料下载CMD55 综合测试仪 CMD55产品特点: ·是测量GSM及GSM1800移动电话的紧缩式单元 ·通过RS232,IEC/IEEE远控 ·前面板有多功能连接器 ·话音编码器/解码器可被集成 ·可选择安培表和伏特表 ·高敏感度二级RF输入 ·可改进为GSM、GSM1800及GSM1900测试 CharacteristicsThe CMD52 is a compact unit for testing GSM900 mobiles. The CMD55 is furthermore capable of testing GSM1800 (formerly named PCN orDCS1800) and GSM1900 (formerly named PCS or DCS1900) mobile phones. Both models are favourably priced and combine small dimensions with high measurement accuracy and speed.The testers range of capabilities includes all signalling, generator and measurement functions required for verifying the correct operation of the DUT (Device Under Test). Thanks to its fast go/nogo tests and accurate analysis using optional extensions, CMD52 and CMD55 are equally well suited for R&D, production and high-end service and production.Based on the wide-range know-how of Rohde & Schwarz in digital radiocommunication testing, which not least was obtained in developing type-approval test systems such as the GSM900 and GSM1800 system simulators, both CMD models are top-grade testers for present and future measurement applications.Test capabilitiesTo test mobile phones, the CMD simulates a GSM900, 1800 or 1900 base station. One of the two RF synthesizers available for this purpose delivers a continuous BCCH signal while the other one provides all 8 timeslots for TCH signals.The major test functions are:Mobile synchronizationLocation updateIncoming call setupOutgoing call setupMobile power level controlHandover (channel change, timeslot change)Peak power measurementHigh dynamic range burst analyzer (option CMD-B4 and CMD-B42)Spectrum due to Switching measurement (option CMD-B4 and CMD–B43)Spectrum due to Modulation measurement (option CMD-B4 and CMD–B43Timing Advance measurementSACCH measurement (eg RxLev, RxQual, power level)Echo testCall clearing by mobile phoneCall clearing by CMDDC current/voltage measurementsPhase and frequency error measurement (option CMD-B4)Measurement of power ramping as a function of time (option CMD-B4)Bit-error rate (BER) and Fast BER measurement (option CMD-B4)OperationOperation of the CMDis extremely user-friendly and requires no detailed GSM/PCN knowledge. The high-contrast, backlit LCD provided with softkeys on both sides allows convenient callup of test routines under menu control. Various network-specific parameters are preset and permit direct testing without any operator control. In addition, it is of course possible to modify all parameters individually in the configuration menus.AutotestThe autotest function enables complete measurement routines to be started at a keystroke without any further intervention by the operator being required. The test results in tabular form are displayed on the screen.Remote controlThe CMD is remote-controlled via the RS-232 or IEEE/IEC-bus interface using SCPI-compatible commands. In the remote-control mode the CMD is designed for fast speed to yield high throughputs in production.Echo testThe echo test allows very rapid go/nogo analysis covering all essential parts of the mobile. Words spoken into the microphone of the mobile are sent to the CMD, stored in buffer memory and sent back to the phone. In this way it is possible to check the whole signal path from the microphone via the RF transmitter section, RF receiver section, modulator, demodulator, signalling section, speech coder/decoder, analog audio components through to the loudspeaker.Testing handheldsIn addition to the normal RF input/output, the CMD has a high-sensitivity input and a high-level output which enable tests on modules or on handhelds with built-in antenna by using couplers like the CMD-Z10.Module testingFault localization in mobile telephones requires various measurement functions that can also be used without signalling so that defective units can be tested down to modular level. The basic model of CMD already provides some of these functions, eg signal generation with or without modulation or power measurements, other functions being available as optional extensions.
HP66332A HP6622A HP6038 HP6032B HP6642A HP6634B HP6644A HP6645A
简介:东莞银通仪器欧阳先生(总经理)13332662998 0769-87912629 东莞市银通电子仪器有限公司直流电源 HP6012B 60V/50A/1000W 直流电源 HP6671A 0-8V/0-220A 直流电源 HP6652A 20V/25A 直流电源 HP6672A 20V/100A/2000W 直流电源 HP6645A 120V/1.5A 直流电源 HP6621A 20V/10A/160W 直流电源 HP6623A 50V/0.8A 直流电源 HP6624A 60V/10A 直流电源 HP6642A 20V/10A 直流电源 HP6634B 50V/100V/1A 直流电源 HP6644A 60V/3.5A/200W 直流电源 HP6645A 120V/1.5A 直流电源 HP66332A 20V/5A 直流电源 HP6622A 50V/4A/160W 直流电源 HP6038A 60V/10A 直流电源 HP6032A 60V/ 50A 直流电源 HP6632B 20V/5A 直流电源 HP6633A 50V/2A 直流电源 HP6634A 100V/1A 直流电源 HP6654A 60V/9A HP6653A PAD16-200L HP6552B DC-POWER HP6011 DVS-300-9 HP6628A HP6268B HP6552A PPS300 Agilent6611C HP6811A HP6542A HP6113D RM-101 HP6643A PM2812 HP6034C PCR500
HP6012B HP6671A HP6652A HP6672A HP6645A HP6621A HP6623A HP6624A HP6642A HP6634B HP6644A HP6645A HP66332A HP6622A HP6038 HP6032B
简介:东莞银通仪器欧阳先生(总经理)13332662998 0769-87912629 东莞市银通电子仪器有限公司 联系人:欧阳先生(总经理) 直流电源 HP6012B 60V/50A/1000W 直流电源 HP6671A 0-8V/0-220A 直流电源 HP6652A 20V/25A 直流电源 HP6672A 20V/100A/2000W 直流电源 HP6645A 120V/1.5A 直流电源 HP6621A 20V/10A/160W 直流电源 HP6623A 50V/0.8A 直流电源 HP6624A 60V/10A 直流电源 HP6642A 20V/10A 直流电源 HP6634B 50V/100V/1A 直流电源 HP6644A 60V/3.5A/200W 直流电源 HP6645A 120V/1.5A 直流电源 HP66332A 20V/5A 直流电源 HP6622A 50V/4A/160W 直流电源 HP6038A 60V/10A 直流电源 HP6032A 60V/ 50A 直流电源 HP6632B 20V/5A 直流电源 HP6633A 50V/2A 直流电源 HP6634A 100V/1A 直流电源 HP6654A 60V/9A HP6653A PAD16-200L HP6552B DC-POWER HP6011 DVS-300-9 HP6628A HP6268B HP6552A PPS300 Agilent6611C HP6811A HP6542A HP6113D RM-101 HP6643A PM2812 HP6034C PCR500
HP4194A HP4261A HP4277A HP4285A HP4275 HP4261 HP4274A HP4262A HP4278A HP4263B HP4275A HP4276A
简介:东莞银通仪器欧阳先生(总经理)13332662998 0769-87912629 电桥 HP4194A 100KHz-40MHz 电桥 HP4261A 120HZ/1KHZ 电桥 HP4277A 10K-1MHZ 电桥 HP4285A 75KHZ-30MHZ 电桥 HP4275 10KHZ-10MHZ 电桥 HP4261 100KHz-40MHz 电桥 HP4274A 100HZ-100KHZ 电桥 HP4262A 120HZ-10KHZ 电桥 HP4278A 1KHz/1MHz 电桥 HP4263B 100 Hz-100 kHz 电桥 HP4275A 10KHZ-10MHZ 电桥 HP4276A 100HZ-20KHZ 电桥 HP4192A 5HZ-10MHZ 电桥 HP4280A 电桥 HP85047A 电桥 HP4271A 电桥 HP4342A 电桥 HP85046A 电桥 MODEL-087 电桥 LCR-816 电桥 PCR-500 电桥 2791 电桥 HP4339B 电桥 LCR-1062电桥 电桥 LCR-301A 电桥 chenHwa102 电桥 HP4262A 电桥 chenHwa102 电桥 ChenHwa205 诠华 102C
HP8702A HPE5100A HP8753C HP8711B HP87510A HP35677A R3767A HP8753C R3762BH HP3577A HP4195A HP8711A MS620J HP8753B
简介:东莞银通仪器欧阳先生(总经理)13332662998 0769-87912629 网络分析仪 HP3577A 5HZ-200MHZ 网络分析仪 HP4195A 10Hz-500MHz 网络分析仪 HP8711A 300KHz-1.3GHz 网络分析仪 MS620J 网络分析仪HP8753B 300KHz-6GHz 网络分析仪HP87510A 100K-300M 网络分析仪HP35677A 100KHZ-200MHZ 网络分析仪R3767A 40MHz-8GHz 网络分析仪HP8753C 300K-3GHz 网络分析仪R3762BH 3G 网络分析仪HP8702A 6GHZ 网络分析仪HPE5100A 10Hz-180MHz 网络分析仪HP8711B 300KHz--1300MHz
HP8350B HP8656A HP8647A HP8657A FLUKE6060A MG-3670B VP-8174A HP8657B
简介:东莞银通仪器欧阳先生(总经理)13332662998 0769-87912629 信号源 Meguro MSG-2570 50K-140MHZ 信号源 Leader LSG-222A 25-950MHZ 信号源 VP-8300A 0.1HZ-2000MHZ 信号源 VP-8178B 100kHz-30MHz,75MHz-110MHz 信号源 FLUKE 6060A 100KHZ-1050MHZ 信号源 MG-3670B 300K-2.25GHZ 信号源 VP-8174A 100KHz~110MHz 信号源 HP8657B 0.1-2060MHZ 合成信号源 TR4511 100KHz-1800MHz 合成信号源Anritsu MG3633A 10KHz- 2.7GHz 高频信号源VP-8179B 10KHz-240MHz 高频信号源 HPE8254A 250K-40GHz 信号发生器 ESG-2560B 100KHz-110MHz 射频信号源 HP8648C 9KHz-3.2GHz 高频信号源VP-8177A 100KHz-110MHz 低频发生器 GAG 808G 10H-1MHZ 高频信号源 HP8640B 10MHz-26.5GHz 函数信号源 HP3325B 1MHZ-50MHZ 扫频信号发生器HP8350B 10MHz-20GHz 合成信号发生器HP8656A 100KHz-990MHz 高频信号发生器HP8647A 250K-1000MHz 高频信号发生器HP8657A 100KHz-1040MHz 高频信号发生器 MSG-2580 10KHz-280MHz 调频、调幅信号产生器 A GSG-122 100kHz ~ 110MHz 多功能合成源 HP8904A 50Hz-100KHz
