MRG has named PanAn Testing & Engineering Co. LTd., as the exclusive distributor of the Grease Thief Sampling and testing technology products for China, Macau and Hong Kong.
The Grease Thief has revolutionized condition based monitoring (CBM) programs across multiple industries by allowing representative grease samples to be taken from in-service machinery.
Historically, it has been difficult to collect a grease sample to analyze that is representative of the grease performing the analysis. Further, attempts to collect these samples often required partial disassembly of the bearing, resulting in expensive equipment downtime.
The innovative design of the Grease Thief solves both of these problems, making grease analysis a valuable tool for improving CBM programs in grease-lubricated equipment. The small size and intuitive design of the Grease Thief allows it to be inserted directly against the bearing face without disassembly of the bearing during the sampling process. In this way, a representative sample of grease is collected with almost no equipment downtime.
The Grease Thief Analyzer was specially designed to utilize the unique structure and small volume of the Grease Thief samples to perform a complete analysis package requiring less than two grams of grease. The innovative test slate measures the wear, oxidation, contamination and consistency of the grease using a variety of chemical and physical methods. Finally, professional analysts use this data to provide custom maintenance recommendations for each individual component.
Grease Thief technology adds tangible value to CBM programs and has already been demonstrated to be effective in multiple industries and applications, including wind power, nuclear energy, robotics, and pharmaceutical manufacturing.
For more information, please visit our website: www.pananchina.com
种下一颗种子,让绿色开花
CANNON miniPV系列——聚合物粘度测量的得力助手
miniAV-LT测量可持续航空燃料(SAF)运动黏度的可靠选择
ASTM D3241-24新推荐——AD 喷气燃料热氧化安定性测试仪TO 10
ECH 无载气全自动卡尔费休水分测定仪
VISAYA 全自动泡沫特性测定仪
CANNON 双浴全自动运动粘度仪 CAV4.2
OilCMS在线油液分析系统
CANNON UltraVIS无溶剂运动黏度测定仪
法国 AD 全自动烟点测定仪 SP20
OilCon Mon在线油液健康状态传感器
Green Lab adem 全自动抗乳化性测定仪
航煤航煤热氧化安定性测定仪
CANNON CCS-2100LT 低温发动机油表观粘度测定仪
miniPV-HX聚合物稀溶液黏度计
miniPV全自动聚合物粘度测定仪
在线油液PPM级水分监测传感器
Oil Filtration KIT油液过滤系统智能监测套件
Atten2 OiHealth PROBE 在线油液健康状态传感器
