方案下载应用领域 | 石油/化工 |
检测样本 | |
检测项目 | |
参考标准 | structure, fluorescence, and magnetism? |
the lanthanide complexes with weak equatorial and strong axial coordinated donors are apt to exhibit good dynamic magnetic
Two new chiral six-coordinate lanthanide complexes (1 for Dy and 2 for Tb) have been synthesized using
the achiral flexible ligand H 2 L (2,2’-[1,2-ethanediylbis[(methylimino)methylene]]bis[4,5-dimethylphenol]).
Both complexes crystallize in the chiral P1 group space, and the enantiomers [Zn(L)Cl] 3 Dy·MeOH·0.5H 2 O
(Λ-1), [Zn(L)Cl] 3 Dy·1.5H 2 O (Δ-1), [Zn(L)Cl] 3 Tb·1.5H 2 O (Λ-2) and [Zn(L)Cl] 3 Tb·H 2 O (Δ-2) are isolated in the
reaction. Three [Zn(L)Cl] − anions coordinate to the central lanthanide ion using two phenoxo oxygen
atoms of L 2− , and the lanthanide ion has the coordination geometry of D 3 . Complex 1 exhibits a field-
induced slow magnetization relaxation, which is typical of a single-ion magnet (SIM). Ab initio calculations
on complex 1 and studies on magneto-structural correlationship of six-coordinate Dy( III ) SIMs indicate
that the small energy barrier of complex 1 might be related to the absence of a unique anisotropic axis for
the regular octahedral coordination configuration of Dy( III ) and the high quantum tunneling gap between
the ground states (m J = ±15/2). Complex 2 displays green photofluorescence and triboluminescence.
S450 近红外光谱分析仪模型测试报告
紫外分光光度法测定虎杖中自藜芦醇的含量
