资料下载The use of microwave-irradiation instead of conventional heating has been demonstrated to result in faster and cleaner reactions and in some cases to different selectivity. In our previous work, we have demonstrated that the use of pressurized microwave conditions results in a tremendous acceleration for the cationic ring-opening polymerization of 2-oxazolines. However, this observed acceleration could be reproduced using conventional heating in an autoclave. Nonetheless, the control over the polymerization was slightly better under microwave irradiation due to the more homogeneous temperature profile. This improved control over the polymerization allowed the synthesis of well-defined triblock and tetrablock copoly(2-oxazoline)s for the first time. In this contribution, the use of ionic liquids, which are well-known as excellent microwave absorbers, as solvent for the microwave-assisted cationic ring-opening polymerization of 2-ethyl-2-oxazoline is discussed. In addition, a continuous flow operating procedure is proposed, in which the poly(2-ethyl-2-oxazoline) is extracted with water and the ionic liquid is reused for the polymerization after removal of the residual water using a microwave-assisted distillation. The second part of this contribution deals with the microwave-assisted cationic ring-opening polymerization of fluorinated 2-phenyl-2-oxazolines. These monomers have never been considered for polymerization since the electron withdrawing substituents on the aromatic system were thought to result in too slow polymerization. Nonetheless, the accelerated microwave-assisted polymerization procedure allowed the polymerization of these monomers, whereby surprisingly fast polymerizations were obtained for monomers with ortho-fluoro substituents.
锂离子电池正极活性材料中由于水处理方法导致的锂和过渡金属溶解
简介:锂离子电池(LIBs)是便携式电子设备和电动工具的能量存储设备,并具有作为替代燃料车辆能源的巨大潜力。SPEX Mixer/Mill是一种高能球磨机,最近在关键研究中用于消除制造过程中对环境有影响的物质。要了解更多关于这项研究的信息,请访问链接https://bit.ly/2Tqe7kH
液相色谱-串联质谱法分析水、固体、生物固体和组织样品中的全氟烷基和多氟烷基物质(PFAS)——美国环境保护署水办公室
简介:液相色谱-串联质谱法分析水、固体、生物固体和组织样品中的全氟烷基和多氟烷基物质(PFAS)——美国环境保护署水办公室
ACCQPrep HP150用于手性化合物纯化
简介:当需要纯化手性化合物时,ACCQPrep HP150可以配备手性柱,可以很容易地进行这种类型的纯化。由于反式二苯乙烯氧化物是手性纯化的标准物,因此它被用作其他手性化合物的模型。
培安微量蒸气压仪同时检测蒸气压和密度
简介:蒸气压和密度是原油、汽油及其中间体最重要的质量参数之一。根据GB/T 11059,ASTM D6377(原油蒸气压),SH/T 0794,ASTM D5191(汽油蒸气压) 和SH/T 0604,ASTM D4052(密度)的测试标准,可在炼油厂的质检室以及整个分配链,如在终端、存储设施,甚至直接在使用移动实验室进行测试。
SPEX高通量组织研磨仪- Real-Time Taqman PCR方法在动物组织样品中提取RNA/cDNA和基因组DNA的应用
简介:本实验样品来自于人、狗、猫、老鼠、牛、马,还有鱼和蛤等新鲜动物组织样品,使用高通量组织研磨法处理,经Real-Time Taqman PCR方法,提取并检测RNA/cDNA和基因组DNA的提取质量,最终得出结论:使用SPEX高通量组织研磨仪研磨动物组织,可以快速高通量的完成样品制备,且核酸提取量高、提取的核酸质量好。
CEM Mars6 高通量密闭高压微波消解仪
EDGE全自动快速溶剂萃取仪
CEM MARS-X 微波溶剂萃取系统
ISCO X系列高压高精度柱塞泵
Hanson 6/8杯药物溶出度仪
ISCO 快速制备液相色谱仪
Katanax X600重型电熔样机/熔融炉/熔片机
CEM Smart 6 通用微波水分测量仪
Hanson 14杯药物溶出度仪
CEM Discover 2.0 300mL腔体环形聚焦单模微波合成仪
SPEX大容量液氮冷冻研磨仪
CEM ORACLE通用快速脂肪分析仪
HG-600 Geno/Grinder (原SPEX 2010)高通量动植物组织研磨机
SPEX BM-400/450高能量球磨机(原SPEX 8000M/D)
SPEX CG-500高通量液氮冷冻研磨仪(SPEX 6875D)
