方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The use of microwave-irradiation instead of conventional heating has been demonstrated to result in faster and cleaner reactions and in some cases to different selectivity. In our previous work, we have demonstrated that the use of pressurized microwave conditions results in a tremendous acceleration for the cationic ring-opening polymerization of 2-oxazolines. However, this observed acceleration could be reproduced using conventional heating in an autoclave. Nonetheless, the control over the polymerization was slightly better under microwave irradiation due to the more homogeneous temperature profile. This improved control over the polymerization allowed the synthesis of well-defined triblock and tetrablock copoly(2-oxazoline)s for the first time. In this contribution, the use of ionic liquids, which are well-known as excellent microwave absorbers, as solvent for the microwave-assisted cationic ring-opening polymerization of 2-ethyl-2-oxazoline is discussed. In addition, a continuous flow operating procedure is proposed, in which the poly(2-ethyl-2-oxazoline) is extracted with water and the ionic liquid is reused for the polymerization after removal of the residual water using a microwave-assisted distillation. The second part of this contribution deals with the microwave-assisted cationic ring-opening polymerization of fluorinated 2-phenyl-2-oxazolines. These monomers have never been considered for polymerization since the electron withdrawing substituents on the aromatic system were thought to result in too slow polymerization. Nonetheless, the accelerated microwave-assisted polymerization procedure allowed the polymerization of these monomers, whereby surprisingly fast polymerizations were obtained for monomers with ortho-fluoro substituents.
【CEM】酸奶中的蛋白质
【CEM】电子设备组件样品制备用于IEC 62321-7-2:2017方法六价铬含量分析
【eralytics】结合蒸气压与密度的测量
CEM Mars6 高通量密闭高压微波消解仪
EDGE全自动快速溶剂萃取仪
CEM MARS-X 微波溶剂萃取系统
ISCO X系列高压高精度柱塞泵
Hanson 6/8杯药物溶出度仪
ISCO 快速制备液相色谱仪
Katanax X600重型电熔样机/熔融炉/熔片机
CEM Smart 6 通用微波水分测量仪
Hanson 14杯药物溶出度仪
CEM Discover 2.0 300mL腔体环形聚焦单模微波合成仪
SPEX大容量液氮冷冻研磨仪
CEM ORACLE通用快速脂肪分析仪
HG-600 Geno/Grinder (原SPEX 2010)高通量动植物组织研磨机
SPEX BM-400/450高能量球磨机(原SPEX 8000M/D)
SPEX CG-500高通量液氮冷冻研磨仪(SPEX 6875D)
