方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Everything you want to know about Zeta Potential: Who wants to know? Maybe you do - especially if you need to control fine particles in lquids. Blood, water, wine, clays, cements, dyestuffs, pharmaceuticals, paints, paper, and ink are all examples of colloidal suspensions. Your goal may be to make a product more effective, easier to prepare, or easier to use. You may want to enhance its shelf life or seperate the particles from the liquid. In almost every instance, your key to control is to modify the colloid''s behavior.
CPS纳米粒度仪在病毒颗粒粒径分布上的应用
高压氢气源在加氢反应中应用
CPS纳米粒度仪在橡胶中炭黑回收中的应用研究
