方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
用NU Plasma, 分析Li同位素,也适合于核工业的同行 Eclogites from Trescolmen, Switzerland, derive from basaltic protoliths that experienced variable degrees of low-T seafloor alteration prior to high pressure metamorphism. N7Li of the eclogites (311 to +5x) ranges to dramatically lower values than observed in fresh MORB, or altered MORB (+4.5 to +14xfor low-T and 32 to +8xfor high-T altered MORB). These low values cannot be explained by fluid interaction with surrounding garnet mica schist, which is generally isotopically heavier (N7Li of +2.4 to +3.8x). The low N7Li values were likely produced by isotope fractionation through Rayleigh distillation during dehydration of clays and/or chlorite at early stages of metamorphism. These data are consistent with isotopically heavy Li being released into the forearc mantle wedge in subduction zones, while an isotopically light component is subducted deeply, and may form a distinct mantle reservoir that could be sampled by plume-related magmas.
用新型辉光放电质谱仪测定高纯金属——记忆效应研究
meinhard
