方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
VACUUM IMPREGNATION EQUIPMENT I 1. Recommended when very small through-holes (<0.032" diameter) need to be filled 2. Should also be used with thick PCB’s (>6 layers) VACUUM IMPREGNATION EQUIPMENT I 3. Air is removed from hole so that edges from rounding 4. Epoxy mounting compounds perform the best under impregnation Buehler’s Epoxide has proven to work the best Acrylics such as SAMPL-KWICK do not work well in a vacuum SAMPL-KWICK in fact, has a tendency to boil 1. Mounting compound is poured into mold in the vacuum The patented Vacuum Chamber Pouring in the mold outside the vacuum and then placing it inside will not remove the bubbles No. 20-1382-160 VACUUM IMPREGNATION EQUIPMENT I, with high strength plastic vacuum chamber, built-in synchronous motor and rotating turn table, pouring mechanism, vacuum gauge and hose, filtering flask, glass tubing, rubber stopper, 100 graduated paper cups, 12 SAMPL-KUPS, 100 vacuum table liners, Drierite dehydrating agent and vacuum pump for 115V/60Hz/1 phase. No. 20-1382-250 VACUUM IMPREGNATION EQUIPMENT I, same as 20-1382-160 but for 220V/50Hz/1 phase operation.
标乐先进的制样技术-Mg及其合金制备
标乐先进的制样技术-汽车车身点焊样品制备
标乐先进的制样技术-片状多层陶瓷电容制样经验分析
洛氏硬度计 RH2150 | 美国威尔逊硬度计 Wilson
美国标乐 Buehler | SimpliVac 真空镶嵌机
美国标乐 Buehler | AbrasiMet M 手动砂轮切割机
Buehler AbrasiMet XL Pro™ 大型砂轮切割机
AutoMet™ 300 Pro 研磨抛光机
多功能硬度计 UH4000 | 美国威尔逊硬度计 Wilson
美国标乐 Buehler | AutoMet™ 250 研磨抛光机
美国标乐 Buehler | EcoMet 30 磨抛机
PlanarMet™ 300台式预磨机
MiniMet 1000 半自动磨抛机
美国标乐 Buehler | IsoMet HS 高速精密切割机
美国标乐 Buehler | SimpliMet 4000自动镶嵌机
全自动维氏/努氏硬度计 VH3300 | 美国威尔逊硬度计
DiaMet 硬度测试软件
IsoMet 1000精密切割机
