1、为保证内容正常显示,图片请使用本地上传。
2、新闻内容不得添加电话、邮箱、QQ、网址、二维码等任何联系方式,新闻底部会自动添加联系我们的功能。
负氧离子检测仪在辽源气象局的使用
负氧离子监测仪
Negative oxygen ion continuous monitor
XZ500B负氧离子连续监测仪采用了独特的采集筒电容器和纯进口信号处理单元,通过精确稳定的电荷采集,测量并显示负氧离子含量。
XZ500B negative oxygen ion continuous monitor contains unique collection tube capacitor and genuine imported signal processing unit through accurate and stable electric charge acquisition to test and display the negative oxygen ion content.
大气负氧离子是带负电荷的氧气离子。负氧离子对人类的健康具有惊人的积极作用,在医学界享有“空气维生素”之美称。大气中所含有的负离子的多少是衡量空气清新的标志之一,根据世界卫生组织划定的标准清新空气的负氧离子含量为每立方厘米空气中不低于1000~1500个。
Negative oxygen ions are oxygen ions that carry negative charges. The ions have astonishingly positive effects on human health, known as “Vitamin in air” in the medical field. The quantity of negative oxygen ion contained in the atmosphere is one of the criteria of fresh air. According to the affirmation of WHO, it can only be regarded as fresh air when the one cubic centimeter air contains about 1000 to 1500 negative oxygen ions.
负氧离子等级标准与健康的关系
一级,负氧离子浓度≤500个/cm3,易诱发生理障碍和各种疾病;
二级,负氧离子浓度500-900个/cm3,维持人体健康基本需要;
三级,负氧离子浓度900-1200个/cm3,增强人体免疫力、抗菌力;
四级,负氧离子浓度1200-1800个/cm3,杀灭、减少疾病传染;
五级,负氧离子浓度1800-2100个/cm3,具有自然痊愈力;
六级,负氧离子浓度≥2100个/cm3,具有治疗和康复功效。
Correlation between Standards of Negative Oxygen Ion and Health
Level one, density of negative oxygen ion ≤ 500 per cube centimeter, physical hinder and diseases are easily induced;
Level two, density of negative oxygen ion 500-900 per cube centimeter, maintains the basic needs of human health;
Level three, density of negative oxygen ion 900-1200 per cube centimeter, strengthens the immune system;
Level four, density of negative oxygen ion 1200-1800 per cube centimeter, kills and reduces bacterial infections;
Level four, density of negative oxygen ion 1800-2100 per cube centimeter, contains natural healing ability;
Level six, density of negative oxygen ion ≥2100v per cube centimeter, contains the effects of healing and recovery.
大气环境监测数据及天气预报显示屏
负氧离子连续检测仪
惠州南昆山负氧离子监测系统投运
重庆酉阳桃花源景区负氧离子监测数据发布系统
