方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract: This paper is focused on the influence of polystyrene (PS)–poly(1,4-butadiene) (PB)–poly(ethylene oxide) (PEO) triblock terpolymers on the w/o microemulsion of the pseudo-ternary system water/sodium dodecylsulfate (SDS)/xylene-pentanol. Despite the insolubility of the copolymer in water as well as in the xylene–pentanol mixture, it can be incorporated into the w/o microemulsion and interactions between the triblock terpolymer molecules and the anionic surfactant headgroups can be detected by differential scanning calorimetry (DSC) measurements. Furthermore, dynamic light scattering measurements were used to determine the aggregate diameter of the modified microemulsions. For lower polymer concentrations large aggregates between 100 and 500 nm can be observed. Surprisingly, at a higher terpolymer concentration of 5 wt%, significant smaller aggregate diameters can be identified by dynamic light scattering and Cryo-SEM. One can conclude that the copolymers are incorporated in the inverse microemulsion droplets, where the PB blocks cover the water droplets. The thermally induced radical cross-linking of the butadiene units in the presence of azobisisobutyronitrile (AIBN) leads then to covalently closed nanocapsules with an average size of 10 nm. Keywords: Triblock terpolymer; Microemulsion; Nanocapsules
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
