方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The effects of two typical additives, lithium chloride (LiCl) and glycerol, on the fabrication of poly(vinylidene fluoride-co-hexafluropropylene) (PVDF-HFP) asymmetric microporous hollow fiber membranes were investigated in terms of membrane morphology, structure, permeation performance,hydrophobicity and mechanical property. The addition of the additives into the dope solution altered the morphology and structure of the resultant membranes, which was believed to be associated with the change of the thermodynamic and kinetic properties of the system in the phase inversion process. The membranes with improved pure water permeability (PWP) from 6.908×10−5 (7) to 4.835×10−4 (49), 3.256×10−4 (33) and 5.003×10−4 L/hm2 Pa(51 L/hm2 atm) were obtained when 2 wt.% LiCl, 4 wt.% LiCl and 10 wt.% glycerol was used as the additive,respectively. Among these, the membrane made from the dope containing 4 wt.% LiCl possessed the highest retention capability of 40 kDa molecular weight cut-off (MWCO). The LiCl or glycerol addition into the polymer dope also made the membranes exhibit a narrowpore size distribution. Moreover, the membrane hydrophobicity was affected less by LiCl and glycerol than by poly(vinyl pyrrolidone) (PVP). The addition of 4 wt.% LiCl into the dope could form the membrane with four times stronger strain strength than the poly(vinylidene fluoride) (PVDF) commercial membrane while keeping similar rigidity.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
