方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Electrochemical synthesis of dinitrogen pentoxide (N2O5) by oxidation of dinitrogen tetroxide (N2O4) in a plate-and-frame electrolyzer was investigated. As the separator, different porous polytetrafluoroethylene (PTFE) membranes were tested in this process and the effects of hydrophilicity and of hydrophobicity on the electrolysis were discussed. The transport ofN2O4 andwater from catholyte to anolyte through membrane occurred in the electrolysis, especially at the end of the electrolysis. The water transport had a much more effect on the electrolysis than that of the N2O4 diffusion. The hydrophobic PTFE membranes had better performance on control of water transport from catholyte to anolyte than that of the hydrophilic ones. Hydrophobicity can increase the chemical yield of N2O5. The membranes with a low hydrophobic surface were preferred. All the hydrophobic PTFE membranes with low resistance have the specific energy of 1.1–1.5 kWh kg−1 N2O5. The current efficiency of 67.3–80.2% and chemical yield of 58.9–60.9% were achieved in production of N2O5. The technique of replacing the catholyte with fresh nitric acid can minimize the transport of N2O4 and water to a great extent, it can further improve the chemical yield and reduce the specific energy. © 2006 Elsevier Ltd. All rights reserved.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
