方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Four sulfonic acid-containing gemini surfactants 9BA-m-9BA (m = 2, 3, 4, 6), 6,60-(ethane-1,2-diylbis(oxy)) bis (3-nonylbenzenesulfonic acid) (9BA-2-9BA), 6,60-(propane-1,3-diylbis(oxy)) bis(3-nonylbenzenesulfonic acid) (9BA-3- 9BA), 6,60-(butane-1,4-diylbis(oxy)) bis(3-nonylbenzenesulfonic acid) (9BA-4-9BA), and 6,60-(hexane-1,6-diylbis(oxy)) bis(3-nonylbenzenesulfonic acid) (9BA-6-9BA), were synthesized and characterized by Fourier transform infrared (FTIR), 1H NMR, elemental analysis, and melting temperature measurements. Their ability to lower the water surface tension and hexadecane/water interfacial tension was measured and correlated with the hydrophobicity and length of their alkyl spacer chain. Their aggregates in aqueous solutions were investigated using dynamic light scattering and transmission electron microscopy. Spherical vesicles could be found in aqueous solutions of four gemini surfactants with an apparent hydrodynamic radius (Rh) of ∼100 nm. The critical micelle concentration (cmc) of four gemini surfactants evaluated by surface tension measurements was 1 order of magnitude smaller than that of conventional single-chain surfactant sodium dodecylsulfonate (SDS). And their C20, the gemini surfactant concentration required for lowering the surface tension of water by 20 mN/m, was about 2 orders of magnitude smaller than that of SDS, showing excellent efficiency at reducing the surface tension of water. In addition, the hexadecane/water interfacial tension could be less than 1.0 mN/m after using pure 9BA-m-9BA in water. Using 9BA-6-9BA the hexadecane/water interfacial tension was reduced to 0.21 mN/m.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
