方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A fluorescent film sensor was prepared by chemical assembly of oligo(diphenylsilane)s on a glass plate surface and was used for the detection of nitroaromatic compounds (NACs) in vapor phase. This design combines the advantages of fluorescent films based on single-layer chemistry and the signal amplification effect of conjugated polymers and provides an effective way to create novel fluorescence sensing films for NACs explosives. The advantages have been demonstrated experimentally by the super sensitive response of the above-mentioned film to the presence of trace amounts of NACs in vapor phase. Further experiments showed that the sensing process is reversible, and the commonly encountered interfering substances have no interference to the process. Fluorescence lifetime measurements revealed that the quenching is static in nature. The super sensitive response, and the reversibility and interference free of the sensing process, make the film a promising NACs sensor.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
