方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
In this work, the enzymatic degradation of poly(butylene succinate-co-butylene terephthalate) (PBST) copolyesters was studied using the lipase from Pseudomonas (Lipase PS). The biodegradation behavior was found to strongly depend on the overall impacts of several important factors as the BT comonomer structure and molar content, thermal characteristics, morphology, the enzyme-substrate, and so forth. Further, the biodegraded residual film samples were allowed to be analyzed by means of gel permeation chromatography (GPC), proton nuclear magnetic resonance (1H NMR), differential scanning calorimeter (DSC), small angle X-ray scattering (SAXS), and scanning electron microscope (SEM). On the experimental evidences, an exo-type mechanism of enzymatic chain hydrolysis preferentially occurring in the amorphous region was suggested for the PBST film samples.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
