方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Different studies have been focused on the interaction between the synthetic material/biological entities. Nevertheless it is not still understood how the different surfaces properties influence the biological response of the implants due to the lack of a thorough characterization. The aim of this work is to thoroughly characterize topographically and energetically the sterilized and polished or blasted titanium surfaces in order to elucidate, in further studies, their influence in surface/protein interactions. The ultimate goal is to define surface characteristics that optimize the biologic responses of implants. Focusing on the first events that occur when introducing an implant material, commercially pure Ti grit-blasted samples with different roughness and different sterilization procedures have been characterized in terms of the dynamic of surface wetting with water and different biological medium. Moreover, a complete and reliable characterization of roughness, wettability, chemical surface composition and surface energy of those materials has been done. The nature of the abrasive particles and the sterilization procedures are the main factors affecting the surface energy and the wettability of polished and blasted titanium surfaces. Steam autoclaving and ethylene oxide increase surface hydrophobicity, consequently the base-Lewis component of the surface energy is altered. Time-related contact angle results indicate that proteins adsorb on titanium surfaces and make them significantly more hydrophilic. Those results provide new insights into the complex relationships between the different parameters of titanium surfaces that govern their surface energy and their wettability behaviour.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
