方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
An amphiphilic tris(dibenzoylmethanato)europium(III) (Eu(DBM)3) coordinated P(MMA-co- EIPPMMA)-co-P(NIPAAm-co-NDAPM) copolymer was synthesized, which exhibited good biocompatibility and emitted strong red luminescence (MMA, methyl methacrylate; EIPPMMA, 4-(1-ethyl-1H-imidazo[4,5- f][1,10]phenanthrolin-2-yl)phenyl methacrylate; NIPAAm, N-isopropylacrylamide; NDAPM, (N-(3- dimethylamino)propyl)methacrylamide). The copolymer could self-assemble into micelles of size around 260 nm, and the micelles were thermosensitive at around body temperature. The drug-loaded micelles showed thermosensitive controlled drug release, and the paclitaxel loaded micelles were capable of being internalized into the tumor cells (A549) and exhibited obvious inhibition to the growth of A549 cells. Importantly, in vivo study showed the self-assembled micelles of Eu(DBM)3 coordinated P(MMA-co-EIPPMMA)-co-P(NIPAAm-co-NDAPM) copolymer uptaken by the larvae of zebrafish could be easily tracked and be eliminated from the body within several days.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
