方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Interfacial tension is an important physical property affecting the droplet formation process in microfluidic devices. This work presents the variation of dynamic interfacial tension caused by slow adsorption of surfactant, as well as its influence on the liquid/liquid microdispersion process in a T-shaped microchannel. Using hexane/water-Tween 20 as the working system, it was observed that the droplet size changed with the variation of surfactant concentration when the concentration of Tween 20 was lower than 10 mmol/L, but hardly changed at higher concentrations, which was caused by the unsaturated adsorption and saturated adsorption of surfactant, respectively. The saturated interfacial tension was measured with an interfacial tension meter, and the relationship between the interfacial tension and the droplet diameter was established. Accordingly, the dynamic interfacial tension with unsaturated adsorption of surfactant was determined. The main factors affecting the dynamic interfacial tension were discussed, and a semiempirical equation was established to characterize those effects.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
