方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Electrochemical Deposition of Conductive Superhydrophobic Zinc Oxide Thin Films Mei Li, Jin Zhai, Huan Liu, Yanlin Song, Lei Jiang,* and Daoben Zhu Center for Molecular Science, Institute of Chemistry, Chinese Academy of Sciences, Beijing 100080, China ReceiVed: June 4, 2003; In Final Form: July 15, 2003 A simple method of electrochemical deposition was adopted to prepare conductive hydrophobic zinc oxide (ZnO) thin films. The surface structures were characterized by sanning electron microscopy (SEM) and atomic force microscopy (AFM). Wettability studies revealed that the surface of the as-prepared thin films showed a contact angle (CA) for water of 128.3 ( 1.7°, whereas the superhydrophobic surface with a water contact angle of 152.0 ( 2.0° was obtained by (fluoroalkyl)silane modification. The superhydrophobic conductive thin films materials may have potential use such as microfluidic devices in the future. It is likely that other oxide materials may be similarly prepared by this method. (请下载全文欣赏)
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
