方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Self-Assembly of Large-Scale Micropatterns on Aligned Carbon Nanotube Films The fabrication of well-defined structures with nanoscale materials is a key technology,[1] and self-assembly is an efficient and often preferred process to build micro- and nanoparticles into ordered macroscopic structures.[2] As carbon nanotubes are attractive materials for nanotechnology because of their interesting physicochemical properties and molecular symmetries,[3–6] it is necessary to control the architecture of carbon nanotubes on the substrates. Most patterned carbon nanotubes are formed on prepatterned substrates or prepatterned catalysts during the fabrication process.[7–9] Herein we report the first use of a long-range force (capillary force) in the self-assembly of three-dimensional (3D) micropatterns on aligned carbon nanotube films through a water-spreading method after the growth of the carbon nanotube. It is considered that low-density regions or vacancies of carbon nanotube films play an important role in the formation of the pattern. Therefore different kinds of highly ordered micropatterned structures have been built in a controlled fashion by introducing vacancies artificially. (请下载全文欣赏)
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
