方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
This paper describes the fabrication of surfaces with different wettability, superhydrophobic/superhydrophilic, and pH-responsive properties. We used a self-assembled monolayer (SAM) of a dendron thiol as the underlying surface for electrodeposition of gold nanostructures. After this modification with a SAM of n-dodecanethiol or 11-mercaptoundecanol, the surface shows remarkable superhydrophobic properties with a contact angle of about 155° and a tilt angle of less than 2° or superhydrophilic properties with a contact angle of about 0°, respectively. Moreover, a large-scale pH-responsive surface was obtained by modification with 2-(11-mercaptoundecanamido)benzoic acid (7) (MUABA). The pH-responsive behavior was amplified by using rough surfaces.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
