方案下载应用领域 | 玩具/消费品 |
检测样本 | 生活用品 |
检测项目 | |
参考标准 | -- |
The quality of indexable inserts is highly dependent on their geometry and surface properties. Durability, feed rates and overall machining properties are influenced by the cutting geometry such as cutting angle and radius. Traditionally, quality assurance methods for geometry accuracy have been restricted to tactile methods. However, tactile measurement devices do not allow the measurement of specific radii or angles due to the mechanical contact of the stylus to the surface. The optical 3D measurement device InfiniteFocus removes inaccuracies caused by tactile inspection methods. It provides highly accurate measurement of angle and profile plus the additional functionality of roughness, waviness. Also, the analysis of faults such as pits, scratches and contamination is possible. Due to the optical inspection quality, output and tool durability become approved.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
