方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
In all tool making processes the reliable form and geometry measurement of highly reflective components is a crucial demand. InfiniteFocus® allows complex details such as steep flanks, cutting angles and cutting edge radii to be quickly and reliably measured irrespective of reflectivity. Even across large areas with a high vertical and lateral scanning range or at complex geometries such as tool-tips, InfiniteFocus® yields robust surface measurement results. Also, due to the use of an additional rotation system parameters such as circular spacing, release angle or other production relevant parameters in milling and drilling processes are measured. The optical form measurement of cutting tools with InfiniteFocus® increase durability, feed rates and overall machining properties.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
