PROTEIN CHARACTERIZATION USING DYNAMIC AND STATIC LIGHT SCATTERING
  • 应用领域:--
  • 检测样品:--
  • 检测项目:--
  • 参考标准:
配置单
Introduction :文章介绍了用Zetasizer Nano ZS 在药物开发中研究蛋白质构相的实例. The stability of a protein formulation to a variety of solution perturbations is critical to its success as a pharmaceutical product. Because of the sensitivity of the protein to solution changes, invasive characterization techniques can be problematic. Light scattering is a non-invasive technique that has received wide acceptance in the area of protein and formulation characterization. The scattering intensity of a small molecule is proportional to the square of the molecular weight. As such, dynamic and static light scattering techniques are very sensitive to the onset of protein aggregation arising from subtle changes in the solution conditions. Today’s generation of light scattering instrumentation includes high powered power lasers, fiber optics, high speed correlators, and single photon counting detectors that facilitate the measurement of protein samples across a range of size and concentration that has never before been achievable.
相关方案
  • 推荐产品
  • 供应产品
  • 产品分类
当前位置:马尔文帕纳科 > 解决方案 > PROTEIN CHARACTERIZATION USING DYNAMIC AND STATIC LIGHT SCATTERING
当前操作系统下微信中暂不支持上传图片功能,如需上传图片请在浏览器中打开!
仪器评分
  • *该厂商需要您留下信息才能下载此方案
提交
