方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Phthalates are a group of chemicals used primarily in the consumer product industry. One of their main uses is as a softener in PVC plastic production for a wide range of products—everything from toys to footwear. They are also used in cosmetics, perfume and pharmaceutical packaging. When used in PVC production, phthalates do not chemically bind to the PVC, but tend to evaporate into the air and leach into water and soil over time. In this way, humans and other living organisims are exposed to these toxic phthalates through direct contact with contaminated food, water and air. Therefore, some phthalate compounds are classified as toxic to reproduction and can cause reduced fertility and/or potential harm to the unborn child.
Thermo Scientific Ramina 过程分析仪在生物制药行业的应用
赛默飞微塑料检测全面解决方案
废旧汽车三元催化器内铂钯和铑元素的测定
赛默飞iCAP PRO系列ICP-OES
赛默飞UltiMate 3000液相色谱
赛默飞 Vanquish™ UHPLC超高效液相色谱系统
赛默飞Vanquish Core液相色谱
Thermo scientific Aquion IC离子色谱
Thermo Scientific Integrion高压离子色谱
赛默飞离子色谱ICS-6000
Thermo Scientific TRACE 1300E 气相色谱系统
Thermo Scientific 气相色谱仪 TRACE 1300系列
Thermo Scientific Niton Apollo LIBS 分析仪
6000型固定污染源挥发性有机物排放连续监测系统
赛默飞Orbitrap Exploris 480 高分辨质谱仪
赛默飞Aquion RFIC离子色谱
赛默飞Orbitrap Eclipse 三合一高分辨质谱仪
Nunc Cell Factory摇床
