方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The ITQ 700 GC-ion trap MS was thoroughly evaluated and showed excellent accuracy at low concentrations for a large number of pesticide residues analyzed in green tea. Using the instrument’s MSn functionality allows the user to identify, confirm, and quantify in one analytical run. The injector demonstrated low endrin and DDT breakdown (< 15%) on a daily basis, proving that the system can analyze active compounds without the need for continual, expensive, and time-consuming maintenance. Calibration curves for most pesticides studied met a linear least squares calibration with a correlation coefficient of R2 > 0.995. The Method Validation Study generated an average % RSD of 10.8% for five replicate analyses at 37.5, 75, 150, 225, 600, or 1200 ng/g and a calculated average LOD of 14 ng/g in tea based on 7 replicate analyses of 7.5, 15, 37.5, 75, or 300 ng/g These results demonstrate that the ITQ 700 can comply with international regulations for the control of pesticides in tea.
Thermo Scientific Ramina 过程分析仪在生物制药行业的应用
赛默飞微塑料检测全面解决方案
废旧汽车三元催化器内铂钯和铑元素的测定
赛默飞iCAP PRO系列ICP-OES
赛默飞UltiMate 3000液相色谱
赛默飞 Vanquish™ UHPLC超高效液相色谱系统
赛默飞Vanquish Core液相色谱
Thermo scientific Aquion IC离子色谱
Thermo Scientific Integrion高压离子色谱
赛默飞离子色谱ICS-6000
Thermo Scientific TRACE 1300E 气相色谱系统
Thermo Scientific 气相色谱仪 TRACE 1300系列
Thermo Scientific Niton Apollo LIBS 分析仪
6000型固定污染源挥发性有机物排放连续监测系统
赛默飞Orbitrap Exploris 480 高分辨质谱仪
赛默飞Aquion RFIC离子色谱
赛默飞Orbitrap Eclipse 三合一高分辨质谱仪
Nunc Cell Factory摇床
