Dilatometer--Operation under vacuum and inert gas
  • 2012-06-01 4次
DIL 801 (Standard-Dilatometer) The horizontally operating DIL801 is a standard dilatometer used for routine tasks in any atmosphere. DIL 802 (Difference-Dilatometer) The DIL802 meets the highest accuracy requirements,because only the difference between two samples is measured and the influence of the sample holder is eliminated. In most cases an inert and an unknown sample are used. With dynamic temperature changes, as e.g. with RCS (Rate-Control-Sinterring) as well as in lower temperature ranges the DIL802 reveals further advantages. The DIL802 can easily be converted for use as a one-sample dilatometer. DIL 803 (Two-sample Dilatometer) The DIL803 is equipped with two LVDTs thus enabling a double sample throughput.
相关资料
当前位置:美国TA仪器 > 资料中心 > Dilatometer--Operation under vacuum and inert gas
当前操作系统下微信中暂不支持上传图片功能,如需上传图片请在浏览器中打开!
仪器评分
提交
