方案下载应用领域 | 制药/生物制药 |
检测样本 | 化药新药研发 |
检测项目 | 其他>方法开发 |
参考标准 | TGA |
The amount of moisture in pharmaceutical formulations is an important quality control parameter because it can affect their long-term stability and ultimate effectiveness as well as short-term processability. Techniques such as Karl Fischer titration, moisture evolution analysis (1,2), and thermogravimetric analysis (TGA) have been used for determining pharmaceutical moisture levels. However, these techniques often have trouble differentiating between “free” surface water (the source of problems) and bound water present in the chemical formulation.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
