方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | -- |
Modulated DSC (MDSC) can be easily understood by comparing it to its well-established precursor, differential scanning calorimetry (DSC). Conventional DSC is an analytical technique in which the difference in heat flow between a sample and an inert reference is measured as a function of time and temperature as both the sample and reference are subjected to a controlled environment of time, temperature, atmosphere and pressure. The schematic of a typical “heat flux” DSC cell is shown in Figure 1. In this design, a metallic disk (made of constantan alloy) is the primary means of heat transfer to and from the sample and reference. The sample, contained in a metal pan, and the reference (an empty pan) sit on raised platforms formed in the constantan disk. As heat is transferred through the disk, the differential heat flow to the sample and reference is measured by area thermocouples formed by the junction of the constantan disk and chromel wafers which cover the underside of the platforms. Chromel and alumel wires attached to the chromel wafers form thermocouples which directly measure sample temperature. Purge gas is admitted to the sample chamber through an orifice in the heating block wall midway between the raised platforms. The gas is preheated by circulation through the block before entering the sample chamber. The result is a uniform, stable thermal environment which assures excellent baseline flatness and exceptional sensitivity (signal-to-noise). In conventional DSC, the temperature regime seen by the sample and reference is linear heating or cooling at rates from as fast as 200°C/minute to rates as slow as 0°C/minute (isothermal).
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
