方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 缓冲液 |
Although it is often assumed that the pH of a buffer solution remains constant during a differential scanning calorimetry (DSC) experiment, the pK of a buffer can in fact change signifi cantly between 0 oC and 100 oC. Such pH changes can result in sample denaturation, aggregation and precipitation that, in the absence of knowledge about the temperature stability of the buffer, could erroneously be ascribed solely to temperature-induced unfolding of the biomolecule.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
