方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 自燃倾向 |
Materials such as coals, coal products (e.g., chars, briguettes) and activated carbons are a self-heating hazard in storage and transportation. Accordingly, work was carried out in the 1970’s (1,2) largely at the Fire Research Station in the UK, which led to the formulation of a test (3,4) for predicting whether or not a particular coal or carbon material was a self-heating hazard. The test wich is very widely used up to the present time, focuses on the quantity critical ignition temperature, and the present author has shown (5) that this is not the most suitable quantity around which to build such a test. The critical ignition temperature provides an indication of self-heating hazards only in the limit where all susceptible materials have the same activation energy (usual symbol E, units J mol-1) for their reaction with atmospheric oxygen. This is very far from the truth, and consequently the tests are unreliable.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
