方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 流变 |
The challenge for studying fast changing systems with rheology such as UV initiated polymerization and crosslinking is multifold. These materials react within seconds and the moduli change over 2 to 3 decades. UV lights must irradiate the sample homogeneously over a short time period and fast data acquisition. An option for UV curing, using parallel plate has been designed for the ARES rheometer. A fast data sampling device with a new correlator has been developed to provide up to 500 dynamic mechanical data points per second, so the modulus build up can be easily followed. Results are obtained for an acrylate-based pressure sensitive adhesive. The curing reaction is studied as a function of the sample gap, UV intensity and UV exposure time.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
