方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 流变 |
Greases are important lubricating systems that are very interesting to a rheologist since they often exhibit strongly time-dependent behavior [thixotropy], and are able to shear thin by several orders of magnitude in terms of they are to function as lubricants, and keep moving surfaces apart from each other, even at high relative velocities. Traditionally greases are measured in terms of base oil viscosity, pumpability [Lincoln Ventmeter] and via a penetrometer [amongst other tests!]. These test types all provide a single number or data points can be obtained under varying circumstances of say temperature or in that an unworked sample is compared with a worked sample, but too often the results form only a relative measure of the grease.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
