方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 压力DSC |
Most military’s greases are formulated for use in severe service environments and multipurpose applications. To meet these requirements, the specifications usually require a wide operational-temperature range; excellent water and storage stability; good shear and oxidation stability; good antiwear and load carrying capacity; and rust and corrosion protection. These physical and chemical properties can change during storage and use. Most of these changes are interrelated and can eventually lead to lubrication failure.?
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
