方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 动力学分析 |
在当今日益激烈的竞争环境下,高性能先进材料的开发尤为重要。许多材料制造商不在专注于单一产品领域,而是越来越趋向于多元化。以至于现在开发研究实验室经常研究一系列有明显的不同物理和化学性质的材料。因为这个原因,分析仪器必须非常灵活,它必须能够容纳存在各种各样的物理状态的样品且不影响其灵敏度和重现性。动态力学分析(DMA)也不例外,本文将讨论使用DMA测量系列材料的粘弹性特征,包括液体、聚脂薄膜、乳胶、预浸料坯和复合材料。
In today’s increasingly competitive environment the development of high performance advanced materials is very important. Many material manufacturers no longer specialize in a single product area but have diversified. As a result research and development laboratories often work on a range of materials that can have significantly different physical and chemical properties. For this reason analytical instrumentation must be extremely flexible in that it must be able to accommodate samples existing in a variety of physical states without compromising sensitivity and reproducibility. Dynamic mechanical analysis (DMA) is no exception and this review will discuss the use of DMA for the viscoelastic characterization of a wide range of samples including liquids, polyester film, latex rubber, prepreg and composites.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
