方案下载应用领域 | 生物相关产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 微量热 |
Microcalorimetric instruments and methods are now essential tools for the general understanding of binding thermodynamics of biological macromolecules and specific biological systems. Provided that the enthalpy of binding is of appropriate magnitude, it is possible to determine affinities, KD, in the order of 10 nM (K=l08 M-1) for 1:1 complexes. One of the most important issues with ITC is the time needed to obtain a full binding isotherm. ITC inherently suffers from the relatively small number of binding experiments that are possible to perform per day. The focus has so far been on improving calorimetric response time of the instruments by various means, like assigning instrumental time constants and applying Tian’s equation to dynamically correct the raw calorimetric signal from a fast step-wise titration. Notably, nothing has so far been done to improve the experimental procedure. At the moment 2-3 h is needed to complete an ITC binding experiment. The number of data points that can be obtained, 20-30 points, limits the range of equilibrium constants that can be resolved from the data. For ITC this range is 1 ≤ KCM ≤ 1000, where K is the equilibrium constant and CM is the concentration of the reactant in the vessel. In this Application Note we show the possibility to shorten the time of an ITC experiment by slow continuous titration into the calorimetric vessel, cITC.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
