方案下载应用领域 | 能源/新能源 |
检测样本 | 一次电池 |
检测项目 | |
参考标准 | None |
A dry cell battery is an electrochemical cell in which the electron transfer of a chemical reaction is conducted outside the battery through an external circuit in a load. The reactions in the battery result in a decrease in the energy content of the substances in the battery, It is this energy decrease which can be used to power a device such as a ?ashlight. It is however not possible to utilize the entire energy because of internal energy losses within the battery. The energy that cannot be used outside the battery is converted to heat within the battery. By measuring this heat the efficiency of the battery may be investigated.
A dry cell battery is an electrochemical cell in which the electron transfer of a chemical reaction is conducted outside the battery through an external circuit in a load. The reactions in the battery result in a decrease in the energy content of the substances in the battery, It is this energy decrease which can be used to power a device such as a flashlight. It is however not possible to utilize the entire energy because of internal energy losses within the battery. The energy that cannot be used outside the battery is converted to heat within the battery. By measuring this heat the efficiency of the battery may be investigated.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
