今天给大家分享的是2014年7月份 《Applied Catalysis B: Environmental》上发表的一篇名为:Self-sustained combustion of carbon monoxide promoted by the Cu-Ce/ZSM-5 catalyst in CO/O2/N2 atmosphere
文章摘要如下:
The Cu/ZSM-5, Ce/ZSM-5 and Cu-Ce/ZSM-5 catalysts were prepared and characterized in this investigation and the catalytic activity of carbon monoxide (CO) combustion under these catalysts was determined by temperature-programmed oxidation. The activity for the CO combustion follows the decreasing order: Cu-Ce/ZSM-5 > Cu/ZSM-5 > Ce/ZSM-5, indicated by lower ignition, light-off, extinction temperature and broader hysteresis determined via both heating and cooling feeding process. The CO adsorbed on the copper sites to form Cu+–CO complexes, monodentate and bidentate carbonates was considered to be the crucial step for CO catalytic combustion. At the CO concentration ≥ 5 vol.%, the CO self-sustained combustion was achieved over the Cu-Ce/ZSM-5 catalyst. One reason is due to formation of Cu2+ ions incorporated into cerium oxides, which are more reducible than the copper clusters, minicrystals and bulk CuO particles. Another reason is attributable to the formation of Ce4+/Ce3+ redox couple, which facilitates oxygen transport on the catalyst surface.
该文章中材料表征采用的是美国麦克仪器AutoChem 2920
详情可参考下面链接:
http://www.sciencedirect.com/science/article/pii/S0926337314004056
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
BTA亮点有多少?直播、视频、好文......一网打尽
拿捏了!双蒸汽穿透吸附全方位直播
