测量接触角来检测表明洁净程度
2010-08-31 10:24  下载量:84
资料下载
Contact angle measurements can determine the surface energy, γ, of a solid. To accurately measure the surface energy, we must use a set of fluids and the Lewis acid/base theory with the contact angles, θ, for each fluid. However, a simple contact angle measurement with water will give an approximate answer. This is useful because almost all "contaminants" on a surface affect the measured surface energy.
资料下载
文献贡献者
相关资料 更多
当前位置: 林赛斯 资料 测量接触角来检测表明洁净程度
