纺织材料表面的接触角的测量
2010-08-31 10:25  下载量:91
资料下载
This sample is an open weave material with a reasonably hydrophyllic fiber. A consequence of this is that the material can not support a sessile drop. However, its apparent absorption is due far more to its open weave than to capillary forces. Basically water "falls through" the surface more than it absorbs into it. This was verified by conducting a capillary rise test where the sample is dipped into a beaker of water and the rise of the wetted portion noted. This sample exhibited very little rise, perhaps a mm. By comparison, an ordinary paper towel (a much denser material) will have a 10 or 15mm rise within a second or two. With this behavior in mind, the following images illustrate its behavior.
资料下载
文献贡献者
相关资料 更多
当前位置: 林赛斯 资料 纺织材料表面的接触角的测量
