方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
This application note will illustrate surface tension and contact angle measurements of molten solder using the FTÅ200 system. The FTÅ200 has an optional Environmental Chamber which can maintain a temperature and, if desired, an atmosphere. The temperature was set to 200°C, hot enough to melt the 63% tin, 37% lead Kester “44” brand rosin core solder used in this work. The atmosphere was air.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
