contact angles on open weave materials
2010/08/23   下载量: 52
方案下载
应用领域
检测样本
检测项目
参考标准
This sample is an open weave material with a reasonably hydrophyllic fiber. A consequence of this is that the material can not support a sessile drop. However, its apparent absorption is due far more to its open weave than to capillary forces. Basically water "falls through" the surface more than it absorbs into it. This was verified by conducting a capillary rise test where the sample is dipped into a beaker of water and the rise of the wetted portion noted. This sample exhibited very little rise, perhaps a mm. By comparison, an ordinary paper towel (a much denser material) will have a 10 or 15mm rise within a second or two. With this behavior in mind, the following images illustrate its behavior.
方案下载
上一篇 n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
下一篇 玻璃接触角的测量
文献贡献者
相关方案
当前位置: 林赛斯 方案 contact angles on open weave materials
