方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
This sample is an open weave material with a reasonably hydrophyllic fiber. A consequence of this is that the material can not support a sessile drop. However, its apparent absorption is due far more to its open weave than to capillary forces. Basically water "falls through" the surface more than it absorbs into it. This was verified by conducting a capillary rise test where the sample is dipped into a beaker of water and the rise of the wetted portion noted. This sample exhibited very little rise, perhaps a mm. By comparison, an ordinary paper towel (a much denser material) will have a 10 or 15mm rise within a second or two. With this behavior in mind, the following images illustrate its behavior.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
