方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Sessile drop contact angles were measured with water on two types of plastic lens with a standard FTÅ200 instrument. One lens had an antireflection coating and the other did not. The purpose of the measurement was to both show the differences between the lens coatings and the process of making measurements on the "side" of a lens where the surface is obviously not flat. A secondary purpose was to see if the curvature of the lens was sufficient that local baseline correction was necessary.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
