方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Viscosity is resistance to flow. Viscous samples require special consideration. There are several separate issues, and these apply whether one desires to measure interfacial tension or contact angles. Viscosity is measured in milli Pascal seconds (mPa s) which is numerically identical to centi Poise (cp). Water has a nominal viscosity of 1cp or 1mPa s. Viscosity is a strong function of temperature, dropping rapidly as temperature rises. A good place to get reference values for viscosity is the CRC Handbook of Chemistry and Physics (www.crcpress.com).
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
