资料下载The TG 5093 fixture consists of a small upper spring loaded wedge grip to clamp the film container cover, and a horizontal sliding bed fitted with a ''dish holder''. A mains operated vacuum pump with associated piping and vacuum control valve is used to apply vacuum to the ''dish holder'' to retain the food container securely in position during the test.The wedge grip is fitted to the supplied threaded adapter and connected to the upper anchor pin on the load cell. The sliding bed fixture is connected to the lower anchor pin.Once the pump is switched on, the food container sample may be positioned in the holder and the vacuum control valve adjusted so that there is sufficient force to restrain the dish when the plastic cover is peeled off. The sliding bed is positioned so that the loose part of the cover is located below the upper wedge grip. By lowering the moving crosshead, so that the wedge grip is just above the dish, the two levers of the grip may be squeezed together to open the jaws, allowing the edge of the cover to be positioned into the jaws. The levers may then be released and the test carried out.
仪尊科技总样本-2015
简介:仪尊科技所有产品简要介绍,包括德国高特福公司,法国Metravib公司,英国Ray-ran公司,荷兰Fontijne公司,德国H&P公司的产品。
毛细管流变仪ISO测试标准
简介:该文件为英文原版ISO11443的毛细管流变仪测试标准,详细的介绍了毛细管流变仪的结构及相关的测试原理及计算公式等。
探讨:什么样的DMA才真正满足我们的应用
简介:目前,越来越多的DMA/DMTA 进入中国市场。让我们有更多的选择。然而,同时也会给我们在设备选型的时候带来很多困惑 - 什么样的DMA/DMTA 才真正满足我们的应用?力值范围和频率范围是两个最重要的指标。下面我仅从这两方面提几点看法,希望能对我们的选型有所帮助。
动态热机械分析仪DMA用于聚甲醛树脂蠕变方面的研究
简介:使用法国01-dB公司生产的动态热机械分析仪DMA 450+测试聚甲醛树脂弹性体在三点弯曲的模式下进行蠕变测试研究。
